I agree, but i need to keep my customers happy, and has you say, to be up with the avaialability and the cost of a VGB board or the Offline Adept windows. Looks like I must write a windows front end in VB.NET to talk serial to the CS7 and Ethernet of the CS7B. I simply need a 3D Libary DLL Function to calculate the positions of joint angles along a trajectory in the way VTRAJSIG does. I have copies of the V+ VTRAJSIG 41A,42B Source code to look at. The calculation takes so long on the Robot to Calculate, The answer must be that it's done on a PC.
COSIMIR, EASY-ROB, seems a possible as they output V+ Code. VISUAL COMPONANTS outputs their own style of code, which can then be proproceeced in to any code, and for me it could be VAL2,V+ or the Kawasaki AS
