jeffroot
- Sep 5, 2006
- 27
I have some basic questions about a stator. Specifically this one is in a motorcycle.
The stator in question is static, has 8 posts, and 2 of them are wound for an ignition circuit. The remaining 6 posts are empty. I am planning to use them for a lighting circuit. Lets assume the lighting circuit comes from the stator as ?V AC, goes to a switch, then a 12v shunt-type regulator/rectifier, then to a 55W headlight.
Q1: If I wind the extra posts to make the lighting circuit, close the switch and run the lights, does this increase the load on the engine? I know its seems like a stupid question, it does right?
Q2: If I wind the extra posts to make the lighting circuit, but leave the switch open and do not run lights, is the engine still feeling the extra load from the stator?
