Static grounding of process vessels inside building
UltrasonicMan
Petroleum
CA
I do not have access to API RP2003 and am wondering if anyone knows if it is acceptable to have vessels housed inside a building grounded through the building's skid. Two corners of the building have ground cables and each vessel is either welded or bolted to the skid. Any info appreciated.
Better ask an electrician
UltrasonicMan,
You will probably get an answer from the following fora...
forum242
forum248
forum238
