Static Calculation for room
Marcus0708
1
Hi all,
I m confusing into a differential pressure equation
Q = 2610 * A * p^1/2
where P is the differential pressure in Inwg
so, my doubt is
I have 2 room where one room is 30pa & another room is 25pa, assuming that Q is adjustable to achieve the static pressure, so what is the P value shall I insert? the 25 or the differential pressure between this 2 room?
The differential pressure is what creates the air movement between the rooms, so 5 pa is the value you want.
