Hi - I'm from Aussie so excuse the SI units. We have a pump system design due for construction later this year. Duty is seawater/mud slurry at 20% solids pumped to a dam 8km distant, with 9km piping rising 112m from pump centreline. I was always of the opinion that you started centrifugal pump systems by starting the pumps against a closed isolation valve and opening the valve slowly, hence accelerating the pipe contents slowly until full flow is obtained. Does the same apply for a (full) system like this with 112m of head already "on" the pump (There is a check valve then isolation valve at the beginning of the main line). For the 750m3/hr normal flow, 2 Slurry 10/8 end suction pumps are used in series. The first is fixed speed, the second VSD. Do we start pump 1 then ramp up pump 2, then open the valve, or open it after pump 1 is started. Any tips ?
