Hello everybody;
We want to use 2 squirrel cage induction motors connected parallel for a water pumping station. At normal operation, only one motor will be running, and if necessary the second one can be started.
The rating of each motor is 370 kVA, 3-phase 380 V with minimum 0.85 PF.
My question is; are there any cicumstances for the starting current of a squirrel cage motor while the other is running? In other words, are the conditions change for starting of an induction machine depending on the present parallel connections?
