Have you ever seen the suction of a standby pump being pressurized up to the discharge pressure of the running pump?
Could this happen if the standby suction line is closed and its discharge line open, regardless of the check valve presence?
In this case rating of suction side instruments (low flow & pressure switches) should be that of the discharge side?
