First post in this forum - starting with a question I hope someone can help me out with; hoping there might be a definitive answer to this one.![[ponder] [ponder] [ponder]](/data/assets/smilies/ponder.gif)
The company I work for currently measures run-out (TIR) on 16 cylinder diesel engine crankshafts by using a steel-topped table, two vee-blocks (not solid vee-blocks, but with rollers) and a dial indicator. Now, some have suggested that a level, solid granite table should be used and others have also suggested that solid vee-blocks should be used instead of vee-blocks with (little bit worn) rollers. Furthermore, because of the length/weight of the crankshaft others have suggested that multiple vee-blocks are required to counter possible deflection of the crankshaft under its own weight.
My question is this - is there a standard method (ISO, ASME, BS, etc.) for measuring crankshaft run-out (TIR) using vee-blocks and a dial indicator? Any insight into standard methods and/or other methods and practical considerations?
Any help would be greatly appreciated.
