standard file selection dialog boxes
stevenw
Autocad 2000i
Standard file selection dialog box.
Views.
We want "list" to be the default not "preview".
how do we change it?
View setting in Select File dialog box is not retained
Published date: 2001-12-06
Applies to:
AutoCAD® 2002
AutoCAD® 2000i
AutoCAD® 2000
AutoCAD LT® 2002
AutoCAD LT® 2000i
AutoCAD LT® 2000
Issue
On the File menu, you click Open. In the Select File dialog box in the Views drop-down list, the view type always reverts to List in a new session of AutoCAD, even after you changed the view type to Details
Solution
This is as designed; there is no way to retain the setting.
I believe the "LIST" option is THE OPPOSITE toggle for "DETAILS".
Preview will always occur whether it's set to LIST or DETAILS.
ALSO ,,,,
By default, AutoCAD is to LIST/ PREVIEW.
BUT WHY?
Would you want the preview window off?
