Mar 14, 2003 #1 S spawnman Guest it will be very useful to me if PRO/e could color a surface with a colour that I specify one time whenever I create any surface... Can any1 help me? Thanks
Mar 17, 2003 Thread starter #2 N nkpham Guest Ummm... I'm not sure how to change the default color. I only change part colors through the View> Model Set Up> Color and Appearance menu.
Mar 18, 2003 Thread starter #3 R Rajesh Guest In the same menu we can color the required surfaces instead of the whole part.
Mar 18, 2003 Thread starter #4 S stoneta Guest View > Display Settings > Entity Colors > Then pick the Geometry Tab
Mar 19, 2003 Thread starter #5 S spawnman Guest ok, well i already knew how to change a color of a surface, i want instead that pro-e make all the surface i make in a specified color, without i change it every time i make a new surface!! thanks
