USAeng
- Jun 6, 2010
- 419
A few guys at our shop are going back and forth about which would be better to use as a return path to ground... about 5/8" braided either stainless or bronze about 15' long... there will be an insulated wire going through carrying the current and then it will return through the braided hose back to ground... anyone know if one will be better than the other? is there a way to measure which is better? our multimeter's lowest setting is a 200ohm scale.... do we need a better multimeter for things like this? Basically- is there something I can do to prove that one will be actually noticably better than the other? Thank you!
