mikeg8
Industrial
- Nov 15, 2005
- 29
Hello All!
I'm really struggling to come to terms with various ASTM standards which I'm sure you all know about...
Example: I'm specifying stainless steel (304 type) butt-weld fittings. The geometric standard for these is ASME B16.9 (I hope, or I've got EVERYTHING wrong!). The material standards I've listed as ASTM A312 and ASTM A240 (depending upon whether the item was fashioned from pipe or plate) and the forming designation as ASTM A403. Schedule of the fitting to suit the pipe size. Is any of that correct or have I got hold of the wrong end of the stick?
Many thanks if you can help
Mike
90% of a project takes 90% of the time...the last 10% of a project takes the other 90% of the time!
Mike
