I have to write How to Install Manual and a Material Specification for couplings in our water distribution system. A problem I am having is what materials the coupling and bolts should be made from. I prefer ductile iron center and end rings with stainless 304 bolts and nuts. I also have to require North American made or meets intent of American Recovery and Reinvestment Act (ARRA). Most cast products are made overseas. Larger couplings are only avaialble in steel. Construction crews hate stainless becuase the nuts and bolts gaul. We require anti-gauling lubricant, but they still sieze. I think the crews use air wrenches. Should I require all steel couplings with epoxy coating? Should I stick with 304 stainless or look into the epoxy coated steel bolts? thanks in advance - Jim
