gte447f
- Dec 1, 2008
- 815
Has anyone here ever seen a type of steel joist roof system in which the top and bottom chords of the joists are offset horizontally from one another, such that the plane of the webs is inclined at an angle rather than being vertical? I have been told it may be referred to as a delta joist system? The top chords are spaced at 4'-0" o.c. and the bottom chords are spaced at 4'-0" o.c., but the bottom chords are staggered 2'-0" horizontally from the top chords. It probably sounds crazy if you have never seen it before. The top and bottom chords are double angles with the two angles being screwed together. The webs are continuous round bars welded to the chords. When all of the chords are screwed together, you end up with a giant space frame as your roof structure. If anyone has any experience with a system like this, I would appreciate any info on who may have designed/manufactured it, and any recomendations as to how to analyze it for additional roof loads. Thanks.
