waytsh
- Jun 10, 2004
- 374
Working on a construction plan for a large grade beam/strip footing and debating how to locate the longitudinal bar laps. The way it is working out with the rebar lengths available if I stagger the laps some of the laps will be in the high moment region under the columns. If I use non-staggered laps I can keep them in the lower moment region, roughly half of the maximum. I am leaning towards using non-staggered laps. The bars are number 8 and they are spaced at over 9" so congestion should not be a problem. Thoughts?
