Stage Discharge by Outlet Device
djmcoc
Hello. Is it possible to see stage discharge by outlet device in a pond summary? If anyone has used Hydrology Studio, you may be familiar with the stage discharge table. Rather than 2 columns (elevation, primary) like hydrocad, you are able to see each outlet device as a separate column.
If you set different routing for each device (primary, secondary, etc,) you will see a separate rating curve for each device. But a compound outlet will be displayed with a single composite curve.
Peter Smart
HydroCAD Software
