EZBuilding
- Aug 26, 2014
- 393
All,
I am familiar with the stability requirements (IBC 1810.2.2) for deep foundation elements based upon how they related to auger-cast pile foundations. I am currently working on a project which is considering the use of drilled shafts or caissons for the foundation system, and was looking for opinions on how that might change the stability requirements. In using a 54" diameter caisson embedded 80' into the soil, I expect that I will have to stabilize the top of the element with grade beams or a mat type foundation as this element would not qualify for the exception 1. "...height does not exceed 12 times the least horizontal dimension." Does anyone have any discerning opinions on this statement?
My comment is brought by having seen drawings which utilize a single drilled shaft below a single column,which does not meet the requirements for the stability exception. There was nominal attachment from the individual pier "cap" to the slab on grade, but at first glance this does not appear rigid enough to stabilize the drilled shaft.
