Hi i need some help. I'm currently designing a 3-storey reinforced concrete house in Staad.pro 2007. Problem is I worked as a design engineer for about one year and then as proj manager for 3 years. So now i'm a bit rusty with my designing. Can someone please look at my design and let me know what i'm doing wrong.
I need help with the following:
1. I know that i have to adjust some of the beams sizes but what about everything else? Is there a way to design the pad footings (individually) without inputting the dimensions for the footing and only the bearing capacity of the soil? Can I use fixed supports and design the footings by hand or will this affect the design significantly?
2. I can't remember if i need to release moments and when do i have to release moments.
3. Is there a way for staad to automatically adjust individual beam sizes that fail? I would normally create a beam spec and add it to all the beams in the structure. Will i have to adjust each beam individually and add each individual dimensions as a beam specification?
