B
bhayden
Guest
I have a thin metal cage that gets assembled to a circuit board. The pins are rectangular in cross section and of course the holes in the PCB are round. I figure adding an axis throught the center of the leg that will be inserted into the hole is the best practice for assembly. My question is, is there a slick way to find the center of the material thickness or should I just measure, offset two planes half the width and material thickness and create and axis at the intersection of the two planes? Seems like the a long way around.
Bernie Hayden
Bernie Hayden
