Sprocket tooth profile
autocol
Automotive
AU
Hey guys,
I'm in a position where I need to cut a lot of sprockets. Of course, existing sprocket manufacturers aren't too keen on giving me the profile of the tooth, and I've had no luck google-hunting.
Can anyone point me to an information source for the correct design of sprocket teeth? The pitch is around the 8mm mark, approximately 50 teeth, 4-6mm thick, to give you an idea of the size I'm dealing with.
Thanks,
Col.
Try ANSIB29.1 1975 it will give you some sizes to compare you wheel against. It is also in Machineries Handbook brown6
Here is the list of related standards:
A…Standard roller chains / ASME B29.1
B…Heavy roller chains / ASME B29.1
C…Extended pitch roller chains / ASME B29.3
D…Standard roller chains (EU) / DIN 8187, ISO R-606, BS 228
E…Standard roller chains (US) / DIN 8188, ISO R-606
F…Extended pitch roller chains / DIN 8181, ISO 1275
G…Low speed sleeve chains / DIN 8164
H…Galle chains / DIN 8150
Mirekp
Mechanical calculations
thank you guys, i will check that when i get back to work...
