Spring with lines and arcs
  • Thread starter Thread starter Rajesh
  • Start date Start date
R
Rajesh
Guest
How to make a spring whose top view looks like two parallel lines joined by arcs (tangent-tangent)?
S Rajesh
you can create a rectangular extruded hollow surface with rounded edges, then create a helical surface around the rectangular surface. Extract the curve from the intersection of the two surfaces and use a sweep to create your spring.
Another way to do it is to form a curve on an extruded rectangular surface using pythagores theorem.
If you need some help with the second method just let me know.
Thank you very much, Jules and proed. I am very clear with the first method. The mentioned site is also very useful.
Jules, I'd like to know about the second method also.
rajeshsundaran@yahoo.co.in
Rajesh...
Check your email for the second method....
Jules
