My attempt to the solution of this problem is as follows.
Let's assume O is the center of the spiral and B is the free end, where a force
P is acting in the direction BO.
One can observe that each half winding of the spiral may be approximated as a semicircular arc with radius
r equal to half the distance of the endpoints.
Now the problem is that of the deflection of a semicircular arc with two fixed ends at A and at B, the ends being free to slide along the diameter. The arc is loaded at A and B by two forces
P directed along the diameter.
This problem is solved in textbooks treating curved beams: my own is a monumental work by Belluzzi (only in italian), but I guess it can be found elsewhere.
The solution to this problem is as follows (hope with no mistake on my part, as some simplifications were necessary):
[ξ]=(
Pr3/16
EJ)(2
[θ]-
[π]+2sin
[θ]cos
[θ]+8(
[θ]sin
[θ]+cos
[θ])/
[π]-4sin
[θ])
[η]=(
Pr3/16
EJ)(4cos
[θ]-2-2cos
2[θ]+8(sin
[θ]-
[θ]cos
[θ])/
[π])
where
[ξ] is the displacement in the direction AB
[η] is the displacement in the direction orthogonal to AB
[θ] is an angle measured from A (where it is zero) to B (where it equals
[π])
and the other symbols are easy to figure out.
Note also that the above equations take the center O as not moving (because of symmetry): this should be accounted for in the following.
Now it shouldn't be too hard to do the following: take first the innermost half winding and calculate its deflection, considering that one end in this case doesn't move, not the center as in the equations above; then take the following one that will start its deflection from the former and so on.
Of course all this assumes that each half winding is a true circular arc and that the deflections are small. However as the solution is obtained from the equivalent of the well known equation
y''=-
M/
EJ, and this one is known to work well with relatively large deformations, I guess that the results could be acceptable even for a spring, where the deflection may be many times the beam depth (or thickness). Anyway don't think that more could be done by analytical means.
Good luck! (you'll need much of it
![[smile] [smile] [smile]](/data/assets/smilies/smile.gif)
prex
Online tools for structural design
