I am involved in a project to provide soil parameters to the project's structural engineer for a seismic evaluation of an existing building.
The structural is asking for:
1. Bearing Pressures with spring factors
2. Soil Passive Pressure with spring factors
For #1, I am assuming that the spring factor which the structural is asking for, is the modulus of vertical subgrade reaction, "k" with Force/Length^3 units. This "k" value is also the same "k" value provided for slab-on-grade design. Is this assumption correct?
For #2, I will provide the passive equivalent fluid pressure depending on the type of soils. However, I am confused about what "spring factor" is. If the building were on piles, I will be able to provide the lateral modulus of subgrade "kh", however the building is constructed on shallow footings. I was checking my geotech books and most of the equations to calculate "kh" requires the diameter of the pile, but in my case since I have shallow footings I do not know what will be the best approach.
Does somebody have an idea what (lateral) spring factor mean? and how to calculate it for shallow footings? or any book references?
Thanks in advance for your help.
