Hi guys, hoping I could get a bit of advise on something I'm stuck on at work.I've recently started using Ansys and have been thrown in the deep end!
The structure I’m modelling in Ansys is on a piled foundation, with each pile descending about 20m into the ground. I want to model these piles using spring elements with a stiffness K. I am unsure, what is the right element spring type to use as I wish to model the support provided by a combination of both the soil and the piles.
I have been using COMBIN14 and COMBIN40 elements. With the COMBIN14 element, I have modelled the support conditions at each pile location by creating, from a node at ground level, a vertical element 1m below the surface and 2 elements in the horizontal directions. These elements represent all 3 orthogonal directions I wish the stiffnesses to be in.
This seems to work fine, but I want to compare this COMBIN14 element to other element types and maybe use an element that’s more robust. Hence I’ve been trying to use the COMBIN40 element! .When I use this element type in a similar fashion as the COMBIN14 and analyze (modal – subspace - extracting 10 modes), it says my nodes i and j for element X are not coincident.
Does this mean I must create 3 nodes at the same location and then create the 3 elements at this same location, between these nodes, specifying the direction/ dof I wish each element to act?
I’m basically unsure how to use the COMBIN40 element type, what are the benefits of one over the other?
I would appreciate any help/advise you could give me and I hope I havn’t completely confused you!
