Spreadsheet question
Slaen
Automotive
I have a spread sheet Im trying to open but catia is cutting the spreadsheet off and I cant view the whole thing. Is there a setting somewhere I can change that?
Are you opening as a design table or in drafting?
Its in Drafting
Try modifying the spreadsheet by using smaller font and smaller column widths and see if that helps
What method are you using to open the file in V5? Save your excel spreadsheet as .csv and make sure you use Table From CSV option in Drafting to import the file.
Along these same lines, I use the import from csv file to create a bill of materials, and when importing the csv file, I always get extra rows above and below my data, as well as extra columns to the right of my data. I've looked around and tried a few suggested "fixes" (fixes to do with how excel exports data in csv format, not fixes relating to catia) but none seem to work.
Anyone have this issue or have input on it?
Thanks.
