Spreadsheet Expiration Date
GregLamberson
Petroleum
Dec 2, 2006
577
All:
I previously posted a request for some input on putting expiration dates on spreadsheets and got some great input that allowed me to get that set up.
A couple of follow up questions:
1) I have the code password protected in VBA, but is there a way to prevent users from simply clicking the disable macros tab on start up?
2) As a follow up to 1) above, a former poster had made the following recomendation - "I would put conditional formating that will make the cells all black if the NOW() function is pass certain date. And maybe put a red statement saying it expires. Make sure you put a password so people cant edit it". The question is how would I add conditional formatting? (at the risk of stating the obvious - I'm not an Excel or VBA expert)
The code I am using is (also from a helpful previous poster):
Auto_Open()
ActiveWorkbook.PrecisionAsDisplayed = False
If Date < #3/26/2009# Then Exit Sub
Bye_Message
With ThisWorkbook
.Saved = True
.ChangeFileAccess xlReadOnly
‘ Kill .FullName
.Close False
End With
End Sub
Bye_Message()
'Self-Destruct Final Message no response needed, just OK
ln1 = "This spreadsheet has a defined expiration date which has expired. After the expiration"
ln2 = "date the spreadsheet will not function. Your data will not be lost. Send the file to the"
ln3 = "author to request an updated copy."
In4= “ “
ln5 = "Author is Greg Test (test@yahoo.com / msg = ln1 & vbCr & ln2 & vbCr & ln3 & vbCr & ln4 & vbCr & ln5
style = vbOKOnly + vbInformation
Title = "International Test Consulting, LLC© December 2008, by Greg"
MsgBox msg, style, Title
End Sub
Any help would be appreciated.
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website:
One method is to make all the sheets of interest "very hidden".
Leave one sheet visible, and on it put "Sorry, Expired" or whatever message you care.
Your AutoOpen code - upon confirming that things have not expired can hide the "expired" sheet and make the very hidden sheets visible.
If someone turns macros off all they see is the "expired" sheet.
It's not bullet proof, but it will discourage most folks.
Conditional formatting does not require VBA, it is built in to Excel.
[link ]
btn_liprofile_blue_80x15.gif" width="80" height="15" border="0" alt="View Clyde Hancock's profile on LinkedIn
[/url]
I believe that the Excel user interface can be manipulated through VBA, so you might be able to delete all the menu and toolbar methods for accessing the macros.
TTFN
FAQ731-376
For some more ideas on ways to protect spreadsheets, including the use of expiry dates, see threads:
thread776-144608
thread770-171136
thread770-217385
This subject keeps coming up, partly because there is no perfect solution.
