We are currently designing and constructing several low rise (2-3 floor) commercial office buildings (all reinforced concrete construction). We have relatively good soils (5000 psf bearing capacity) and our geotechnical engineer has recommended conventional spread footing foundations. However, when considering the time and costs to excavate and construct individual footings, pedestals, grade walls and then backfilling and compacting the same with small equipment before placing a slab on grade, would it not be less expensive and much faster to just place a thick raft slab in one pour??? My old text book says a mat (or raft) foundation should be considered when conventional spread footings cover more than 50% of the building footprint, but does the same still hold true in today’s market, especially if the construction schedule is really tight? Any comments or advice would be greatly appreciated.
