electricpete
- May 4, 2001
- 16,774
I saw the following tidbit in Gate's belt PM manual:
"When a belt drive is excessively noisy, the belt is often incorrectly blamed. It is easy to eliminate the belt as the problem by spraying it with soapy water while it is running. If the noise goes away, or decreases, then the belt is part of the problem. If you still hear the same noise, the problem is likely due to other drive components."
I'm at a loss to understand what that's all about. What is the physical effect of spraying water... does it improve the traction between the belt and the groove?
