Hello
We are getting a lot of rust on one of the products we spot weld. The rust is only on/around the spot welds. Picture is attached.
From my understanding this happens because the heat of the weld in a oxidizing environment (ie open air spot weld/unsheilded) will:
1. burn off the millscale layer exposing bare steel to the environment.
2. change the microstructure of the weld metal/HAZ making it more susceptible to rust.
Can any one else explain this more thoroughly? and if possible suggest any solutions?
