Hi All:
We're in the business of restoring classic italian sportscars (mostly pre '55) which includes Maserati, Alfa Romeo, Fiat derivatives, etc. Our problems deal not only with good fastening systems but also retaining original appearance.
For example, early Fiat (up to ~ '53) used internal star washers over a beveled flat washer when fastening a nut on a stud to hold an aluminum component. If it was a steel component, then only the star washer was used. Early Alfa is different, they used split lock washers over a similiar beveled flat washer. For rods and mains they used cotter pinned castle nuts. Maserati is different again........and of course the French and Germans had their ways. I point this out because in my business hardware originality (in appearance) is important for the history of the car and judging events,
Having said that, for all critical apps, such as main bearing caps, rods, cylinder heads, flywheels, clutch components, et all, I try to use modern fasterners. For mains or rods, never a split lock or even a wavy washer as I've seen both break, especially, if re-using a split lock. So we always use hardened, surface ground parallel washers. For external non-critical apps and original appearance requirements, we use the orig hardware which usually includes split locks.
Final comment concerns old bolts and studs...........the Italians and other euro countries mostly machined their bolts. Maserati did their own in-house as did Alfa. But Alfa engineering was better and knew to have a radius under the head of the bolt. Maserati machined theirs sharp - often leading to failure. So check your hardware carefully if you're restoring old cars and re-use bolts (which we often do).
Curious if others have made siimiliar discoveries in the resto field?
