I have an application that uses a split row evaporator coil (6 high, 4 deep – 2x single pass). The capacity control 50/50 of the evaporator coil is no monger needed and it would be much easier if I have 1 TEV and liquid distributor instead of 2TEV and 2 Distributors. Will it make any difference in performance if I replace the 2 TEV with a single one?
I can replace the slit row coil with a coil that has all 12 inlets at the side air out. Will that improve performance of the evaporator coil?
