Hi all!
I'm working with ANSYS Workbench v11 and I'd like to know if there's a limitation in the use of splines in DesignModeler. That's because if you change a parameter of a spline (like the position of a point) and then change it again to the initial value, sometimes you don't get the same spline and even sometimes you get strange and useless shapes, but the constraints (tangencies or coincident points) continue satisfying. In order to avoid it is necessary to set values of curvature, does anybody know how to do it?
Changes in splines are used for the process of optimization (DesignXplorer) and some strange shapes give fails. I know the problem is solved by using firstly a CAD software but I'm really interested in doing it all together in ANSYS because then I want to run it in batch mode to use an external optimization method.
Thank you in advance
