I am a designer, and I realize I still have much to learn with regard to splines I very much appreciate your help.
On several projects in the past I have reverse engineered splines. On occasion I have been able to identify them according to ANSI Standards. I have used the attached Table to provide the required information on my drawings. As The JIS standard Module 2.0 doesn't show the same information I am wondering how to display the necessary information, and for what information to display?
I read on on page 296
of the previously mentioned manual, that the fits are classified into 4 types Loose, Sliding, Fix, and Press Fit.
I want a Loose fit based on my sample.
Perhaps I misunderstood on page 302 Annex Table 2 where a Loose Fit coincides with a tooth flank fit Class A. I thought that meant on the module page, for a 22 tooth (Nominal Diameter 48 mm)Spline Item # 19 Class A was my Variation of tolerance.
I realize I may have more than one question wrapped up here but your continued assistance is appreciated. Ultimately I want to make sure my drawing has all the required data on it.
Cheers,
Aaron
