goodvibes
Aerospace
- Apr 25, 2001
- 18
here's a challenging problem.
How would one calculated the min axial force required to cause an involute spline to slip under a continuous torque. This is for a long drive shaft with male spline on one end mating with a female spline (with roon for axial movement). The design requires that the drive shaft be allowed to move axially while turning to accomodate intermittant thrust loads. The only givens are the spline design dimensions and the Torque and RPM for the drive.
Egads! I'm having college flashbacks!!
Thanks in advance for any help.
