Spline Import
kettch
Computer
I scanned in a sketch and traced over it in Illustrator, then I exported to DXF, however solidworks won't import it. The import wizard runs, and gives a preview of the sketch but it throws an error. Sorry, I'm writing this a day later and from a computer that has internet access, but the error says something about splines and has a list like this:
handle: 2c
handle: 3b
and it doesn't do the import.
Any thoughts? Is there a better way to go from Illustrator to solidworks, or maybe somewhere I can get a checklist for the best way to make a drawing in illustrator that will be most compatible?
-Thanks
Why not trace the scan in SolidWorks? Import your scan to a sketch and make the spline directly--will save a lot of hassle and keep things as native as possible.
Open a new sketch, then, Tools > Sketch Tools > Sketch Picture. Select your scan (JPEG or whatever), select the size you want it to appear (scaled) and it's part of your sketch. You can then start a new sketch over the scan and use splines or whatever you like to get perfect data. Works with photos, too.
Jeff Mowry
Industrial Designhaus, LLC
Yeah, that's probably what I think I'll do. Thanks!
This sounds like an OK solution if you need to do a logo one time but there has to be faster way if one frequently needs to work with designers handing over .ai drawings.
I've been able to solve some DXF import issues by deleting the header from the DXF file. This is done by opening the DXF file in a text editor (Notepad or Wordpad) and deleting the header information there.
[bat]"When everyone is thinking alike, no one is thinking very much." --Eckhard Schwarz (1930--2004)[bat]
When I had access to several pieces of software, I would read in a DXF from Adobe Illustrator into CADKey, use "Interpret splines as polylines" and then export it back out and into SW. Then it was just a series of short straight lines. If SW would work on the import code to read splines, this would be great. I am sure that Solidworks is becoming more and more commonly used and many engineers have to incorporate data from Adobe Illustrator into their files.
