I try to design two splines that are controlled in two differnt sketches.
Spline Nr.1 is the waterline / bottomline of a surfboard, the other one / Nr.2 is the deckline.
There is associative points (offset along curve) on spline Nr.1
Spline Nr.2 is controlled by the endpoints of lines ( in the same sketch as spline Nr.2) that are coincident to the points on spline Nr.1 and perpendicular to spline Nr.1.
Now, if I want to remove a controll point of spline Nr.1, I get an error message : Internal memory access violation.
I have been in contact with my local UG support and they reported this to UGS, but sofar no answer for quite some time.
Thanks for any Help,
Seb
Seb
