I am working on re-designing a spline coupler that failed. I do not have a lot of the details of the coupler that failed, as we had no involvement with the original design. Pictures of the failed coupler are attached. It is believed that it was made from 4340 and heat treated to RC 32. Looking at the coupler, it appears that the spline was manufactured rather poorly and I believe the profile might not have met the required standard. The coupler shows clear signs of overheating.
This coupler mates an engine to a splined male shaft. The male shaft is made from 15-5 PH H925 stainless. The torque transmitted by the engine is approximately 350 ft-lbs, but spins at speeds up to 20K RPM. There is another shaft currently being used in place of the adapter that works without any problems. It is made from nitralloy 135M and the internal spline teeth have been nitrided. The shaft is almost identical to the spline coupler, but measures roughly 18 inches in length.
My questions are:
The hardness of the male shaft made from 15-5 stainless is around RC 42. The original plan was to make the adapter out of nitralloy 135M, since the working shaft is made from that alloy. However, with the teeth being nitrided and the surface hardness being much greater than that of the male shaft, would that pose any problems? In general, shouldn't the hardness of both the male and female splines be similar? So if one is case hardened, shouldn't the other be hardened?
Would it not be better to choose a material with similar strength while closely matching the hardness of the 15-5?
Any help is appreciated.
My questions are:
