This is the lisp as from the previous link , it is english for a better understood.
;; A.Dudek
;;; 3DSPIRAL.LSP
;;; Copyright (C) 1993 by Autodesk, Inc.
;;; Permission to use, copy, modify, and distribute this software
;;; for any purpose and without fee is hereby granted, provided
;;; that the above copyright notice appears in all copies and that
;;; both that copyright notice and this permission notice appear in
;;; all supporting documentation.
;;; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED
;;; WARRANTY. ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR
;;; PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED.
;;; DESCRIPTION
;;; This is a programming example.
;;; Designed and implemented by Kelvin R. Throop in January 1985
;;; This program constructs a spiral. It can be loaded and called
;;; by typing either "spiral", "3dspiral" or the following:
;;; (cspiral <# rotations> <base point> <horiz growth per rotation>
;;; <points per circle> <start radius>
;;; <vert growth per rotation>).
;;; Revision 3/9/95 Anthony Dudek
;;; Fixed problem of not drawing a full 360 degree helix when using only one
;;; rotation of 3dpolyline
(defun myerror (s) ; If an error (such as CTRL-C) occurs while this command is active...
(if (/= s "Function cancelled"
(princ (strcat "\nError: " s))
(setvar "cmdecho" ocmd) ; Restore saved modes
(setvar "blipmode" oblp)
(setq *error* olderr) ; Restore old *error* handler
(princ)
(defun cspiral (ntimes bpoint hfac lppass strad vfac / ang dist tp ainc dhinc dvinc circle dv)
(setvar "blipmode" 0) ; turn blipmode off
(setvar "cmdecho" 0) ; turn cmdecho off
(setq circle (* 3.141596235 2))
(setq ainc (/ circle lppass))
(setq dhinc (/ hfac lppass))
(if vfac (setq dvinc (/ vfac lppass)))
(setq ang 0.0)
(if vfac
(setq dist strad dv 0.0)
(setq dist 0.0)
(if vfac
(command "_3dpoly"
; start spiral ...
(command "_pline" bpoint) ; start spiral from ;base point and...
(repeat ntimes
;;; section of revised code
(if (= ntimes 1) ; if the number of
;rotations is 1
(repeat (1+ lppass) ; then calculate points ;one extra time to allow
; for the missing polyline segment at the end of
; the rotation
(setq tp (polar bpoint (setq ang (+ ang ainc))
(setq dist (+ dist dhinc))
(if vfac
(setq tp (list (car tp) (cadr tp) (+ dv (caddr tp)))
dv (+ dv dvinc)
(command tp) ; continue to the next point...
);close inner repeat
;otherwise
(repeat lppass
(if vfac
dv (+ dv dvinc)
);close if
);close main repeat
(command ""
; until done.
(princ)
);close defun
;;; Interactive spiral generation
(defun C:SPIRAL (/ olderr ocmd oblp nt bp cf lp)
(command ".undo" "group"
(setq olderr *error*
*error* myerror)
(setq ocmd (getvar "cmdecho"
(setq oblp (getvar "blipmode"
(initget 1) ; bp must not be null
(setq bp (getpoint "\nCenter point: "
(initget 7) ; nt must not be zero, neg, or null
(setq nt (getint "\nNumber of rotations: "
(initget 3) ; cf must not be zero, or null
(setq cf (getdist "\nGrowth per rotation: "
(initget 6) ; lp must not be zero or neg
(setq lp (getint "\nPoints per rotation <30>: "
(cond ((null lp) (setq lp 30)))
(cspiral nt bp cf lp nil nil)
(princ)
(command ".undo" "end"
(defun C:3DSPIRAL (/ olderr ocmd oblp nt bp hg vg sr lp)
*error* myerror)
(initget 7) ; sr must not be zero, neg, or null
(setq sr (getdist bp "\nStarting radius: "
(initget 1) ; cf must not be zero, or null
(setq hg (getdist "\nHorizontal growth per rotation: "
(setq vg (getdist "\nVertical growth per rotation: "
(cspiral nt bp hg lp sr vg)
(princ)
(defun C:3s ()
(C:3dspiral))
(princ "\n\tC:SPIRAL and C:3DSPIRAL loaded. "
(princ "\n\tStart 3DSPIRAL command with 3S"
(princ)
Pardal
