EnginerdNate
Aerospace
Hi all, aero structures guy needing some help. I normally analyze things that don't move (running loads in bonded aircraft longeron/spar/bulkhead joints for example) so I'm a bit out of my wheelhouse here. We've got a test setup in which we need to pull on a ball joint. The joint geometry is dictated by flight hardware that I have no control over, and we're a sub on this project so I don't have direct access to the info on how the joint was originally designed.
The TLDR is--a ball in a two-piece socket made up of two plates bolted together, each with half of the sphere machined into it with an exit hole large enough to clear the ball's mounting shank plus some space for angular misalignment. This gets a tension load applied to it during the test. I could see the socket shearing out or bearing out, the ball deforming enough to pull out, or the socket deforming enough elastically to let the ball pass through, depending on material choice and geometry, but I don't see a straightforward way to run some hand calc checks on this. Is there any kind of industry standard calc for this type of situation or am I stuck resorting to contact modelling in my FEM program?
Thanks,
Nathan
Thanks,
Nathan
