Dear colleagues,
I am a beginer in the field of mechanical engineering and i need to know what kind of gear i need to lift a 10 tons wheight if i use a 22 Kw / 750 rpm 8 pole electric motor.
The application consists in a electrical winch that pulls rail cars to a loading bunker with linear speed of 10 meters/minute.
The designer calculated that to pull a 700 tons wheight on railway we must use a 10 tons lifting capacity winch. The problem now is to find a speed reducer to do this job. Someone told me that i need a 63 ratio speed reducer but i think this is to small for this requirement. I attached the data sheet of the gear(3H-B-645 with the ratio of 63)
