Specifying wobbling (shaky motion) to a moving and rotating part
mechdrive1
71
Hello everyone,
I am trying to simulate the drilling of an aluminum layer by a screw bit. The tool (screw bit) used is of tool steel alloy and is defined as a rigid body. The aluminum layer is defined as the Eulerian workpiece (in order to eliminate element distortion issues). The tool is provided with a rotational and a translational movement against the fixed aluminum layer. My problem objective is: To specify a wobbling or a shaky motion to the rotating and moving tool against the stationary workpiece. The motive behind providing a wobbling/shaky motion is to simulate the movement of the tool inside the tool holder to check the influence of this wobbling motion on drilling.
Currently, I am specifying the rotational and translational feed using the velocity boundary condition in ABAQUS/explicit. The rotation and linear feed for the tool is along the Z-direction.
I would really appreciate it if you could provide any suggestions or ideas as to how the wobbling motion can be achieved in Abaqus.
Ankit
You can use acceleration boundary condition with specified amplitude for this purpose. Check the documentation example "Seismic analysis of a concrete gravity dam" in Abaqus Example Problems Guide.
@ FEA way: Thank you for your suggestion. I will go through the example and try to utilize it for my model.
