abusementpark
I want to know how to specify a weld to get an effective throat equivalent to 3/16" fillet weld. See the attached sketch. Thanks!
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Packer & Henderson said:It is more important for the design engineer to provide actual loads to be transferred rather than elaborate weld symbols. The specifics of the joint depend on the weld process to be used and on the weld position (flat, horizontal, vertical or overhead). It is common practice for the fabricator to provide weld joint cross sections on the shop drawings to complement the weld symbols if necessary to clarify weld details.
