Special Oil
123Cat
AU
Im looking for the oil or additive that helps 2 stroke GP 125CC engines survive at the end of the sraight when the throttle is closed
There is one
123Cat
Just keep the throttle open and hit the kill button for a bit. The cyl. stays lubed until the temp. is lower.
Just add PowerUp NNL690G to the mix at the recommended dose. This product, which is out of Calgary, Canada is NASA approved and has been used with great success here in NZ by some of the top karters. Your engine will produce more power and last longer too....
