ihopeitworks
Aerospace
I currently have a 2HP, 3PH, 60Hz AC motor, that is connected directly to a 12" dia drum. In the past, I would pull a cable that is wrapped around it with 2 lbs of tension (torque of 1 ft-lb). I have a new project that I am working on that requires a 10.75" dia drum pulling a cable that will have 25 lbs of tension (torque of 11.2 ft-lb). My current motor is not adequate to handle this task so I am now looking for a new motor and VFD to swap out. The kicker is I'll need to be able to apply 11.2 ft-lb of torque at both 120 RPM and 1400 RPM. The reason for the different RPM is that I need to pull this cable at two different speeds, but at the same tension.
How would I go about spec'ing in a motor for this sort of application? I would hope I can get to both RPM within 10 seconds or so. I have a panel wired to step up 120 VAC to run at ~230 VAC. It seems very difficult to find a motor's torque curve for the entire RPM range, it seems that they're only included for the high RPM end.
Looking for any guidance. Thanks.
