SPA / DMU sectioning issue
Runz
Aerospace
As of today, my DMU (SPA license) sectioning results have changed...and not for the better.
Is there a CATSetting that effects the results of sectioning. Just last week, when I sectioned a CATProduct, each component sectioned in the color of the solid model. Now everything is sectioning in a shade of green, as though I am not using the SPA license. The image on the left is how my sections appeared last week and the image on the right is what I am seeing today. As far as I know, I have not changed any settings.
Also, all the parts in contact appear to be merged together into one solid.
See attached pic
Thanks,
 http://files.engineering.com/getfile.aspx?folder=4f299595-0467-47f7-b229-3f5c378f69df&file=Area_fill_-_Shading.jpg
I've seemed to have tried everything within the DMU tab and nothing worked.
I have not changed the background color.
Where do I check the "Swap visible space"?
Also try going to the DMU Sectioning tab and click the button in the lower left that when you mouse over says "Resets parameter values to default ones".
When you're in the process of a section cut there is a button along the bottom of the CATIA toolbar that let's you swap from what's in the visible space to what's in the hidden space. If you click that button usually the background color goes to a light green/blue or turquoise as you have shown in your screen grab.
Drew Mumaw
Rebooted a third time and everything is working fine...
