SP 0.0
Guest
I've Service Pack 0-14 but can't install without SP 0.0
Does anyone know where I can find it?
Thanks!
Sound like you are trying to install SW01 SP on a computer that has SW01Plus. If I remember correctly, it was in SW01Plus that they started to use service pack "X.X" numbering. If you have a legal copy of SW01Plus, you should be able to contact your VAR for the help you need. "The attempt and not the deed confounds us."
Exactly!
I'm trying to install SP 0-14 into SW 2001 Plus... but have no chances unless SP 0.0 is installed before.
Is this problem only mine?
Exactly!
Exactly!
Let see if I understand what your trying to do. Your using SW01 SPX and you want to upgrade your current version from SW01 to SW01+?
Well for
1) SW01+ is only on SP4.
2) SW01+ comes on a CD and it installs SP0.0 when you install it.
3) you can't upgrade SW01 to SW01+ with a SP you hace to have that SW01+ CD.
But to answer your question in a different way. If you are trying to install a SP for SW01 to SP14 then you need to DL the SP that fits your needs.
Example: If your using SW01 SP4 then you need to DL the SP that goes from SP4-14.
HTH, Scott Baugh, CSWP [spin] [americanflag]
credence69@REMOVEhotmail.com
*When in doubt always check the help*
Just to clarify, you can't install SP 0-14 on a machine that has SW2001Plus installed. SP 0-14 is only for use with SW2001, not SW2001Plus.
Think of SW01Plus as an entirely new program... might help to think of it as SW2002 (ok, maybe that didn't help). "The attempt and not the deed confounds us."
If you are on 2001Plus all the features of 2001 Sp0 - Sp14 are already in 2001Plus and the some. MadMango hit it on the head. 2001Plus and 2001 are two different Software releases(Programs). BBJT CSWP
