Whatever you find be careful that they are not isolated, so touching the load could be dangerous. Besides, as they might work with a zener diode to regulate the voltage, if you disconnect the load this IC will get warmer. So when you wanna disconnect your load, turn of the AC voltage not simply switch off the load.
If you'd like a discrete suggestion: feed a Zener (12 Volt- 10W) through a resistor serial with a forward diode, and put a proper dc capacitance in parallel with zener to damp the possible ripple.
I hope it would help
Zimbali
