monkeysolder
I hope this is in the right forum -
We are having an unusual problem with a piece of equipment that uses a 2.5" fixed hard disk drive housed in a small, water and airtight sealed enclosure. Prior to sealing, we purge the entire enclosure of air using tetrafluoroethane. (Commonly available in 'canned air' electronics dusting products). This is a common process on our other equipment, but the first time we have done this for a device housing a disk drive. A problem has just emerged where we are seeing a number of failures for the hard drive and I was wondering if this may have to do with the "air bearing" that the read/write head on the disk platter rides on during operation. Could there not be enough gas density (or perhaps too much), which is causing the air bearing to fail?
Thanks,
Thanks,
