Some Help with Pro? Mechanica Analysis
  • Thread starter Thread starter omarsudan
  • Start date Start date
O
omarsudan
Guest
How can I find the value of the stress at a specific point in or on the design? By using the dynamic query, I
omarsudan,<br style="font-weight: normal;">Have you tried creating a datum point, and placing a measure on the datum point? You would then be able to examine the stresses at that point.
Hope this helps,
8675
Dear 8675,
I tried that before, but; unfortunately, it didn
If we can't find the stress at specific point, then ProMechanica is useless. In the real life experience, we need to know the stresses and deformation for specific points. If there is an expert reading my post, please solve this dilemma. Thank you all.
Hii all,
I just wanted to let you know that I found the solution to my problem. After you create the datum point and insert a measure, on the run status window look for the measure that you created. You'll find the value of the stress at that point. Thank you all.View attachment 2342
