It's my first thread, thus Hello Everybody. I hope you're well.
The problem is as follows.
I drew in-context spring into a shock absorber assembly. It works fine: when I move the piston rod and hit 'rebuild', the spring automatically changes its shape to fit the distance.
When the shock absorber becomes sub-assembly and is placed between frame and swingarm (in top assembly) the spring isn't moving anymore. I've made this sub-assy flexible but spring stays in the same position as in the shock absorber assembly (not updating to fit the current position of shock absorber).
I have attached drawings:
1. Position A
2. Position B - spring not updated, even though I hit 'rebuild'
Thanking you in advance,
Hubert
1. Position A
Hubert
